Very simple Python Script, but it's not worked
I just make a node like below and I insert a level to this python script from a node(Levels). I don’t know why this Python script’s not working. it’s basic node so I think it don’t need additional importing…
import sys
dataEnteringNode = IN
# Place your code below this line
a = Level.Elevation(IN[0])
OUT = a
It might be wise to show what the input is into this node plus what is the error that is indicated?
If working with revit element, then you need to add the import modules for revit
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
IF you are inputting dynamo revit elements into this python node then you also need to unwrap the element accordingly with
#Input and unwrapping
input=UnwrapElement(IN[0])
Lastly if you are inputting a list of elements into this python node you should really do a loop to iterate over the list.
OUT=[]
for ele in input:
	OUT.append(ele.Elevation)
This then means the completed code would look like the following if all of the above is true
# Import RevitAPI
OUT=[]
for ele in input:
Example:
Edit: added a image to help show the code in practice plus that the data from Elevation is in feet and therefore may need to be converted to your units if needed. EG in my case we usually utilise Millimeters.
Please use the code format </> in the editor menu to make the code more readable
Although we can access the Dynamo namespace in a Python node, for simple access such as this a Code Node is going to be more straightforward.
My python script is differ with your 2nd case??
IF you fully read what i have indicated it should help you understand what each bit of code does and then there is a completed code example that implements all of what i said.
Hopefully this helps but do indicate what your original error was!
Hello, this is if you don’t have a loop to manage.
#class you want
from Autodesk.Revit.DB import Level
lvl=UnwrapElement(IN[0])
OUT = lvl.Elevation*0.3048
the base node also exists
Sincerely
christian.stan
