How to get multiple Elevation Marker Locations
I found a python script that accurately finds the point of an elevation marker. (For some reason, the scripts that require the active view do not provide the the marker location, just a point that is associated with the view.)
em = UnwrapElement(IN[0])
if em.HasElevations:
	OUT = doc.GetElement(em.GetViewId(2) ).Origin.ToPoint()
	OUT = "this marker has no views"
(My view ID happens to be 2 instead of zero; this was intentional).
The problem is that it doesn’t seem to work very well with lists; I can only feed in one elevation marker.
I am not very familiar with python though and I was wondering if someone could help me out.
Here is a snapshot of the graph:
The python script that accepts a list is displaying points for a bounding box. They are way off.
Get elevation marker location.dyn (14.8 KB)
Python - Getting XYZ from Location
Why not wrap the python in a custom node?
Thanks @jacob.small, I will give it a shot.
Also, would you know how to add an input for the view Id?
Sometimes the index is 2, but other times it is 0.
Never mind that last question.
@jacob.small, that was very helpful.
I have to correct myself though - the python script that you want to use for this task is the one shown below. I guess it helps if your Dynamo preview is not turned upside-down :stuck_out_tongue_winking_eye:
clr.AddReference('RevitAPI')
elev = UnwrapElement(IN[0])
view = UnwrapElement(IN[1])
bbox = elev.BoundingBox[view]
minPt = bbox.Min.ToPoint()
maxPt = bbox.Max.ToPoint()
OUT = minPt, maxPt
bounding Box of an Elevation Marker
Hi @daniel1
Did this work for you? The first Python script you posted worked for me but, as you say, it only works with one elevation marker. I can’t seem to get the latter script to work though. Did I miss a step?
Honestly, its been kinda finicky. It seems to work better in big projects and not so well in smaller ones. Strange behavior and I’m not sure why.
