Rotate curves issue Revit API
Hi everyone,
Can any one explane me why I’m getting gaps in rotation of my both inner and outer curves, even though the curves count is correct?
please check my refrences belows
1st script: dynamo curves
import sys
import math
from Revit.Elements import Element
element = IN[0]
cover = IN[1]
rebar_type = IN[2]
spacing = IN[3]
geo = element.Geometry()
surfaces = geo[0].Explode()
s_area = []
for i in surfaces:
    s_area.append(i.Area)
S_area = ["%0.2f"%(round(i,2)) for i in s_area]
surf = []
surf_area = set()
for s, a in zip(surfaces, S_area):
    if a not in surf_area and S_area.count(a) == 2:
        surf.append(s)
        surf_area.add(a)
out_V_crv = surf[1].GetIsoline(0, 1).Explode()[0]
iner_V_crv = surf[0].GetIsoline(0, 0).Explode()[0]
out_direct = out_V_crv.Direction
iner_direct = iner_V_crv.Direction
if out_direct.Z > 0 :
    out_V_crv = out_V_crv
    out_V_crv = out_V_crv.Reverse()
if iner_direct.Z > 0 :
    iner_V_crv = iner_V_crv
    iner_V_crv = iner_V_crv.Reverse()
vect = out_direct.Cross(Vector.ByCoordinates(0,1,0))
out_V_rebar = out_V_crv.Translate(vect, cover)
iner_V_rebar = iner_V_crv.Translate(vect, -cover)
overlap_length = rebar_type.GetParameterValueByName("Diamètre de barre")*50/1000
out_V_rebar = out_V_rebar.ExtendEnd(overlap_length)
iner_V_rebar = iner_V_rebar.ExtendEnd(overlap_length)
out_path = surf[1].GetIsoline(1, 0).Explode()[0]
out_path = out_path.Offset(-cover)
iner_path = surf[0].GetIsoline(1, 0).Explode()[0]
iner_path = iner_path.Offset(-cover)
OUT = out_V_rebar, out_path, iner_V_rebar, iner_path
Revit curves
import sys
import math
clr.AddReference('RevitAPI')
out_curv = IN[0][0].ToRevitType()
out_path = IN[0][1].ToRevitType()
iner_curv = IN[0][2].ToRevitType()
iner_path = IN[0][3].ToRevitType()
cover = IN[1]/0.3048
spacing = IN[2]/0.3048
def rebar_rotation(circle, space):
    sweepAngle = (space * 360) / (circle.Radius *  2 * math.pi)
    return sweepAngle
out_angle = rebar_rotation(out_path, spacing)
iner_angle = rebar_rotation(iner_path, spacing)
out_count = int(math.ceil(360/out_angle))
iner_count = int(math.ceil(360/iner_angle))
out_rot_curvs = []
for i in range(0, out_count):
    a = i*out_count
    rota_curv = Transform.CreateRotation(XYZ.BasisZ, a * 2 * math.pi/360)
    out_curvs = out_curv.CreateTransformed(rota_curv)
    out_rot_curvs.append(out_curvs.ToProtoType())
iner_rot_curvs = []
for i in range(0, iner_count):
    a = i*iner_count
    iner_curvs = iner_curv.CreateTransformed(rota_curv)
    iner_rot_curvs.append(iner_curvs.ToProtoType())
OUT = out_rot_curvs, out_rot_curvs
rotated_rebar.dyn (14.1 KB)
Shaft_rebar.rvt (3.4 MB)
Thanks.
Testing this way, seems to provide equally spaced results. Circles are curves with a startpoint/endpoint. So technically there are 159 points with 158 spaces. Have you accounted for that in your code?
Oh my bad!!!..I made mistakes in my code and I corrected it as following and that solved my issue
Thanks.
