i work with Revit 2019 and Dynamo 1.3.
i try to placed adaptiv families on a 3d polyline.
The family has two parameters with which I can rotate the family around the x axis and the z axis.
The rotation around the x-axis works, but the rotation around the inclined z axis is inaccurate or wrong.
Well…i think i found my mistake:
After i calculated the angle i subtract 360° with the angle…
Without the subtraction i get a good placement of the family.
Ok…this wasen’t the final solution.
With new axis data I get clearly wrong results.
The strange thing is that the elements are placed worse with increasing distance from the beginning.
Start:
End:
The greater the difference between the project coordinate system and the positioning coordinate system, the greater the error.
The best results are obtained by pulling the vector of the Y-axis onto the placement plane:
Shure, you can build a adaptive family with 2 Points.
Create one an place a reference line on these 2 points.
Now place a circle on the end of the reference line.
Create now an extrution (reference line and circle combined)
