Has anyone pulled the room number from a space and them wrote it to a paramter in a plumbing fixture in revit?
Dang it was making it harder than it has to be again hehehe
thanks
No problem! I’ve seen a lot of people do the intersection methods, which work but are more complicated. Thankfully Family Instances have a method.
i am having troubles finding the node in rhythm
Do you have the latest version installed?
yes i think so i just downloaded it into dynamo
yes
found it
thanks for all the help
have you ever had issues with the get parameter value by name not working?
it says Warning: Internal error, please report: Dereferencing a non-pointer
@Kendrick.Cross I think you mis-typed “Number” as “Nunmber”. If that is not the case, it is because you will need to filter out those null values and the corresponding elements. If this doesn’t make a lot of sense, feel free to start another topic with images / examples to walk through it.
it worked fine but all of the sudden it stopped working, even with Number spelled correctly
Might want to use BuiltInParameters for this…
