Room: Name access from dynamo
Hello everyone, how can I get access to te “Room: Name” parameter in dynamo. The parameter I am talking is the one of the image
Thanks a lot!
@Rick check this:
Didn’t work, for some reason I can’t get the room from plumbing fixtures and others familys
Do you have phasing in your project?
Are the rooms and fixtures in the same phase?
Is there a phase after whatever phase they are on?
OHH, yes, i have phases!
They are not in the same phase
But why Revit can get the Room Name, and dynamo can’t?
Dynamo definitely can.
if you share one sample file then I can try.
Yes. Dynamo can do it. Rhythm for example is hard coded to get the room in the same phase of the family instance. Code here. I believe that stands true for the OOTB node as well.
For your workflow, you will need a node that allows you to input a phase to “search” in. Let me see if I can add that to Rhythm.
But if you are comfortable copying and pasting a python script. This one should do it:
# import common language runtime
# Import RevitAPI
clr.AddReference("RevitAPI")
# import all classes from Revit DB
# import Revit dynamo libraries
# custom definition for getting room that works with single items or lists
def GetRoomInPhase(item,phase):
	return item.Room[phase]
# the family instances
items = UnwrapElement(IN[0])
phase = UnwrapElement(IN[1])
# return the results
if isinstance(IN[0], list): OUT = [GetRoomInPhase(x,phase) for x in items]
else: OUT = GetRoomInPhase(items,phase)
SampleDyn:
FamilyInstanceGetRoomInPhase.dyn (11.1 KB)
Yes, of course
Here: look at the two plumbing fixture, image it is a renovation
Project1.rvt (2.1 MB)
Home.dyn (5.3 KB)
Look the schedule, I can get the room name
But in dynamo not
Ok, now i get it!
I have elements demolished in “phase 2”, but all my rooms are in the phase 2, I’d like to get my elements in phase 1, and know in which room from phase 2 are they.
Revit can do this in schedules, but i can’t figure out how to do this in dynamo
hmm, there are other ways so let me take a look on my end.
Here we go. This one works off of point locations. This is nice because you can move the points around in Dynamo if you know that your element location is a bit off.
FamilyInstanceGetRoomInPhaseAtPoint.dyn (12.8 KB)
and the python:
# Import RevitAPI
def GetRoomInPhaseAtPoint(point,phase):
	try:
	    return doc.GetRoomAtPoint(point.ToRevitType(True),phase)
	except:
		return None
locations = UnwrapElement(IN[0])
if isinstance(IN[0], list): OUT = [GetRoomInPhaseAtPoint(x,phase) for x in locations]
else: OUT = GetRoomInPhase(locations,phase)
Thanks!
