Hi all, I am currently trying to adopt a script from this link:https://wrw.is/collect-elements-in-rooms-across-linked/
to extract room name and room number from the link models and write into elements in the current model, unfortunately, there is an error at the “element.SetParameterByName” showing:
Warning: No function called SetParameterByName on a Function that takes __array,Function could be found
and the output node from Bakery node “ElementsInRoom” shows “Function”.
Hope there will be a solution for this, thank you!
Does the “Link Rooms Collect Elements” node just need a third input? Some nodes require all of their inputs to be filled else they’ll output a function rather than data. Even if you’re don’t need the parameter data, just slap a third parameter in there to fulfill all the inputs and see if the node fires properly.
