I’m using the add-on for Robot Structural Analysis in Dynamo. Having difficulties with the node NodalLoad.ByNodes.
The issue being that I have a list of nodes and a list of load values which I would like to combine in the mentioned node one by one.
Is there a way of doing this using the node? What later appears in Robot has all the loads values applied to all points and changing the lacing doesn’t seem to solve the problem.
See attached capture.
