I’ve been using the RIE package and so far has worked amazing on Revit 2018, however I believe the API for 2017 is maybe a little different. Is anyone able to help me change it to suit or can advise an alternative?
from Autodesk.DesignScript.Geometry import *clr.AddReference(‘RevitServices’)
from System.Collections.Generic import *clr.AddReference(‘RevitNodes’)
clr.ImportExtensions(Revit.Elements)clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB.Electrical import *
from Autodesk.Revit.DB import MEPSystemclr.AddReference(‘DSCoreNodes’)
import DSCore
from DSCore.List import *import sys
pyt_path = r’C:\Program Files (x86)\IronPython 2.7\Lib’
sys.path.append(pyt_path)Import List ( ICollection(ElementId) = ListElementId )
clr.AddReference(“System”)
from System.Collections.Generic import Listdef tolist(obj):
if isinstance(obj, list):
return UnwrapElement(obj)
return [UnwrapElement(obj)]#The inputs to this node will be stored as a list in the IN variables.
input = tolist(IN[0])electComponents = ListElementId
for i in input:
electComponents.Add(i.Id)doc = DocumentManager.Instance.CurrentDBDocument
app = uiapp.Application
uidoc = DocumentManager.Instance.CurrentUIApplication.ActiveUIDocumentTransactionManager.Instance.EnsureInTransaction(doc)
newcircuit = ElectricalSystem.Create(doc, electComponents, ElectricalSystemType.PowerCircuit)
OUT =
OUT.append(newcircuit)TransactionManager.Instance.TransactionTaskDone()
