Isolate Elements in View, how?
I am almost done!
clr.AddReference('RevitAPI')
clr.AddReference('System')
elements = UnwrapElement(IN[0])
view = UnwrapElement(IN[1])
ActiveView = FilteredElementCollector(doc,doc.view.Id)
isoElems = []
for items in elements:
	isoElems.append(items.Id)
view.IsolateElementsTemporary(isoElems)
OUT = "Done!"
How can I say, do the task in “this” view?
KR
Andreas
replace this line
by this
ActiveView = FilteredElementCollector(doc,view.Id)
or delete it if not necessary
2022-02-17_10h17_16
still remains something.
:slight_smile: what is the difference between a list and collection!?
A list is a pure Python Object, a ICollection is a .Net object (embedded by IronPython in your case), and IsolateElementsTemporary need a .Net Collection
try this
isoElems = List[ElementId]()
for item in elements:
	isoElems.Add(item.Id)
that means i need ironpython libraries too?
Actully when i use append,… is there a differnt syntex?
Because ElementId does not exist, i would rather use a as a basket.
import sys
sys.path.append(r'C:\\Program Files (x86)\\IronPython 2.7\\Lib')
OUT = "Done!"
it works this way! Thank you
It’s to define the type of .Net Collection
read this
https://ironpython.net/documentation/dotnet/dotnet.html#accessing-generic-types
