How to get the room from my linked electrical elements?
so far it works with my ruff script, BUT … i get no rooms
clr.AddReference('RevitAPI')
clr.AddReference('System')
Elements = UnwrapElement(IN[0])
OUT = []
for i in Elements:
	OUT.append(i.Room)
i want to count my poweroutlets i have different ones… and also other stuff, i have to address them to my rooms!
KR
Andreas
We can’t see what you’re supplying the python node but I think LinkElement is a custom class, not a Revit one, so those objects won’t work with the API.
@Nick_Boyts ,
how can i get the outlets? room by room… ?
Geoemtry intersect?
KR
Andreas
You can still use the method you’re using, you just have to supply Revit elements and not a custom class from a custom package.
@Nick_Boyts ,
something like this?
Yes. Now I think you have to use the Room (Phase) property since these are linked elements. Otherwise it’s probably looking the last phase in the active document.
@Nick_Boyts
i can`t find nothing similar… have i sort by phase my rooms? they are all new
Get the phases from the link document and then check for a room at each phase (or just the last one if you know that’s where all the rooms exist.)
@Nick_Boyts ,
thanks i will check out tomorrow
@Nick_Boyts ,
thats what i have so far… names of the variables are not correct
i want to get rooms of my outles! the outlets are linked. Rooms are in current doc!
docLink = FilteredElementCollector(doc).OfClass(RevitLinkInstance).ToElements()[0]
outlets = UnwrapElement(IN[0])
FromRoom = []
for i in outlets:
	for phase in docLink.Phases:
		if i.CreatedPhaseId == phase.Id:
			try:
				from_room = i.FromRoom[phase]
				FromRoom.append(from_room)
			except:
				FromRoom.append(None)
			continue
OUT = FromRoom
KR
Andreas
  1. get the location of your outlet:
    pt = outlet.Location.Point
  2. get phases
    phases = [p for p in doc.Phases]
    phases.reverse() # check last phase first
  3. check its room:
    for p in phases:
    room = doc.GetRoomAtPoint(pt, p)
    if room:
    break
This is the critical information we were missing.
An element has to have access to a room in order for Revit to know it’s located there. In the active model, that can either be in the same document or a linked one (as long as the rooms are loaded). In a linked document, the elements won’t check the active model for rooms.
In this case, you have to go by geometry/location - something like @newshunhk has suggested.
@newshunhk @Nick_Boyts ,
ok until phase reverse it runs well… but the last part does not work… i am not shure about collecting the rooms…
#get the location of your outlet:
pt = []
output = []
for i in outlets:
	pt.append(i.Location.Point)
#get phases
#check its room:
for p in phases:
		if room:
			output.append(p)
		break
OUT = output
grafik
KR
Andreas
Tells you right there you have an unexpected indent. Your if/break loop at the end has an extra indent under room.
@Nick_Boyts ,
it still remains
pt = []
output = []
for i in outlets:
#get phases
#check its room:
for p in phases:
	if room:
		output.append(p)
	break
OUT = output
The room and if/break lines should be aligned.
for p in phases:
	if room:
		output.append(p)
	break
@Nick_Boyts ,
i´ll check tomorrow, thanks
for p in phases:
	if room:
		output.append(p)
		break
I want to break the loop once it found a room and not continue to other phase
you can change a bit the concept yourself
sometimes happens. I usually delete the space in front of the coding and ‘tab’ myself, it happens sometimes when I copy code from here.
