Rhynamo: Shared Coordinates vs Project
Hello everyone,
I have a Revit model where I have been using shared coordinates.
I export it to DWG with Coordinate system basis as: Shared.
I open it in Rhino add some lines that I want to use in Revit.
Now when I read in Dynamo via Rhynamo it is not aligned with my Revit model, but it is placed far away.
If I export with project internal instead, it is aligned.
Do you know why this is happening ?
Many thanks.
Simone
Hi Simone
the reason for this is that Dynamo uses the internal coordinates (not shared coordinates)
You’ll find some posts on this forum about working with shared coordinates in Dynamo- basically translating between the two
Andrew
