Hi There,
I Have a little issue in the link with a Node which name “RhinoTranslationToDS…”!
Indeed, I would like to create a facade from Rhino to Revit, so I used the same script that last time and it worked
but it was a simple polyline extrusion!
Here the shape is just a bit more complicated but not so much!
If you have tips For me, it could be really nice of you!
Thank you very much!
Creation floors and walls from polycurves V2.dyn (334.6 KB)
façade.3dm (535.3 KB)
You must create a mass for sloping walls and use the Wall by face function/node.
You should make an example in Revit to understand how the function works.
Yes I’m gonna try that!
Just to recap : I have to creat a Mass in Révit and use a wall.byface node in this script connected with the “wall.ByCurveAndHeight” or connected to “Polycurve.Curves”
Am I correct?
There is no more need for Wall.ByCurveAndHeight node. The inputs of Wall.ByFace node are a surface (of a mass) and a type of wall.
So it’s two different script!
But could I generate the whole facade with this process?
Probably.
I never use Rhino files so I discover like you the workflow.
Ok! Thank you very much for your Help!
I’ll keep in touch to tell you if it’s working!
So the Wall.ByFace node doesn’t seem to work in this case.
However once you have a family mass in Revit, you can use the Revit wall by face function.
Creation walls from rhino mass.dyn (13.6 KB)
I was wondering why the Wall.ByFace node was not working.
I found that if the mass have no defined Work Plane, the node doesn’t work.
So the solution is to place the Mass family on a Work Plane to create the walls.
