Hi All,
The node ‘‘RhinoTranslationToDS.Rhino_AllGeometryToDS’’ is not working.This node is from Rhynamo package . I am using Dynamo 1.3.2. and project was 2016 version. The story behind this 1018426-Jll-Roller Coaster - Lift Framing_1.3.2.dyn (80.0 KB) is when i setup the script my machine has only dynamo 1.3.2 and Rhino 5 . That time The node was working properly . Due to a new project requirement i had to install dynamo for revit 2019. Now when i am working again for the old project ( revit 2016 version ) i uninstalled dynamo for 2019 ( cleaned ) and reinstalled dynamo for for revit 2016 (1.3.2) . i am using the same script and same Rhino model but the node is not working .
attached is the snap showing the error message and script for your reference.
thank you very much in advance for your any help and suggestion .
Ranjan
