Revit Versions in ZTN
How can I mantain a Dynamo Zero Touch package to work with multiple Revit versions?
Thanks!
you would pick the lowest api version you want to support stick with that - so it will work on all versions - unless a newer API removes an existing method (rare)
in that case you could use system.reflection to check if the API exists before calling it - though this is slow.
I would usually make multiple package versions for each revit version. Yes, it is time consuming - from experience, we know that as Dynamo itself maintained 3 versions of Revit compatibility at a time.
I think others on this forum like Thomas Mohan and Ksobon probably have better/more experienced answers than me though.
I’m in the same situation. I’ve been notified that Wombat has an issue with the Wall.ByCurveAndLocation node (Use of Wall.ByCurveAndLocation fails in Revit 2021 and 2022 · Issue #2 · woodsbagot/WombatDYN · GitHub) and apparently the problem is that in Revit 2021 and above they changed the way to get the UnitType property from the Revit.DB namespace :unamused:
I wouldn’t want to have 2 versions of the package just to change one line of code…sounds ridiculous!
Is there an efficient way?
@Thomas_Mahon @Konrad_K_Sobon how do you guys do this?
Depends, if your issues are restricted to a few depreciated methods - e.g. units conversion, then this is the technique I use in BimorphNodes to provide backwards compatibility so I only need to maintain and distribute one version of the app (it avoids reflection too): Host App Backwards Compatibility - #6 by Thomas_Mahon
Just take note of the limitations of this approach.
Thanks @Thomas_Mahon this sounds exactly like what I need to do. I’ll give it go!
@ATassera I support multiple different versions of the revit api’s via multiple dynamo packages. It’s not for everyone but works for me. GitHub - ksobon/archilab: this is archi-lab.net dynamo repo
Thanks Kornad as well!
@Thomas_Mahon I’m trying your way and it’s really clever, but there’s one part I dont’ understand, which is when you decide which method you’re going to use (if the 2020 or the normal one) you are testing which Revit version is it, you use this code:
nodeServices.RevitVersion < NodeSettings.RevitApiNewUnitsVersion
but I don’t understand where that’s coming from and I can’t call it in VS
(sorry I’ve never done much ZTN so I might a bit noob in this field :smiley: )
Hi @andrea.tassera
Good question! So nodeServices is an instance of BimorphNodes NodeServices class (its an internal) and its RevitVersion property is initialized with the following so I have access to the Revit version at runtime:
        /// <summary>
        /// Returns the current version number of Revit as an int.
        /// </summary>
        private int GetRevitVersion(Document document)
            int revitVersionNumber = Convert.ToInt16(document.Application.VersionNumber);
            return revitVersionNumber;
NodeSettings is a class of public constants, where RevitApiNewUnitsVersion simply stores the following:
        /// <summary>
        /// The version of the Revit API which introduced the new ForgeTypeId units class.
        /// </summary>
        public const int RevitApiNewUnitsVersion = 2021;
Thanks @Thomas_Mahon that worked like a charm. Thanks for sharing!
I love how simple, and in its way elegant, it is. I never thought of it before, but I’m a big fan now.
