Revit - Dynamo - Trim/Extends and wall join
Hello for ,
I’m posting this because I can’t find a node (package) or even the Revit API
  • The same thing as the Trim/Extend tool in the UI.
  • The wall join tool and joint modification, I’d like to define a “do not clean the joint” setting for two walls.
Thank you in advance for your help!
Hello @CBAA_dauvin and welcome :wink: genius loci package have some nodes for wall join
Thank you for the quick reply.
It works exactly as I needed!
