Hi All,
After generating Structural Framing families using Dynamo, is there a way to join the connecting beams using nodes in Dynamo? I want to show the joints in Revit, but I don’t want to manually assign it, because on a larger scale there will be several hundred joints.
Hi Danny,
Nice speaking today. I’m actually surprised this does not exist yet in Dynamo as a node or in the Package Manager. Check inside some of @andydandy’s nodes
Here is the Revit API, it should be pretty easy to access these via Python or DS:
http://revitapisearch.com/html/854c88ca-9bed-7997-3326-dcc53c6335c0.htm
-matt
Hi Danny,
here is a quick Python script to start using the
JoinGeometryUtils
clr.AddReference("ProtoGeometry")
# Import RevitAPI
clr.AddReference("RevitAPI")
walls = UnwrapElement(IN[0])
wall = []
foundList = []
app = uiapp.Application
for i in range (0,len(walls)):
wall = walls[i]
#search for existing joined elements
elList = Autodesk.Revit.DB.JoinGeometryUtils.GetJoinedElements(doc, wall)
for elemId in elList:
foundList.append(elemId)
OUT = foundList
attached are python examples of all methods in JoinGeometryUtils
column joined to wall colum joined to wall
http://revitapisearch.com/html/3eaaf4f5-70b7-f7fb-63a2-0d95bab25deb.htm
Correct me if I’m wrong but isn’t the joining tool( and thus the related API calls) used only for RC elements? While steel members use the coping tool, which from what I can tell does not have an API equivalent.
Dimitar, you are correct in that the joing tool isn’t working for structural steel members. Fortunately enough, you are wrong about the availability of the coping tool in the API.
I just uploaded version 0.74.1 of package Clockwork to the package manager - among other new nodes it contains three new coping related nodes: FamilyInstance.CopingElements, FamilyInstance.AddCoping and FamilyInstance.RemoveCoping. One of them was on my todo list for the next few weeks in any case, so no big deal. Enjoy!
Great work as usual, Andreas!
I’ll be sure to try your nodes later this week.
Thanks Matt, sorry about the late reply been busy getting the Dynamo script setup for the project we were discussing. I’ll be sure to give those scripts a try.
Unfortunately I can’t test the latest version of Dynamo yet due to internal testing requirements by the office’s IT.
