Revit Dynamo Python Error
Howdy,
I have been trying to write something to create sheets and place views on them. In my search for pieces I came across a youtube video that shared a script with custom nodes in them. I have recreated the python portions of it but I am getting some error messages that I do not understand. See below screen grabs. In googling these, I came across some Iron Python vs Python issues. I have followed all the steps in the GitHub blog post to remedy those. I am thinking maybe there is another issue in here somewhere. This is my first attempt with Python so I am not that great at reading or understanding it yet. Sorry if it is obvious. Both of these yellow nodes have the same errors. I can only post one image so I linked to the images below.
The lib you might want to load is clr.AddReference(ā€˜RevitAPI’)
not
clr.AddReference(ā€˜Revit API’)
Whelp, that helped it to run past line 4 but now its giving me a different error message on each of them. I have pasted the two node text bodies below if that helps. I am not sure what the errors mean. Error message images are here:
Make Sheets
clr.AddReference(ā€œRevitNodesā€)
clr.AddReference(ā€œRevitServicesā€)
sheets = IN[0]
views = IN[1]
x = IN[2]
y = IN[3]
viewsplaced = list()
TransactionManager.Instance.EnsureInTransaction(doc) # you need an active transaction as you will create elements
for Number in range(len(sheets)):
sheet = UnwrapElement(sheets[number])
view = UnwrapElement(views[number])
Viewport.Create(doc,sheet.Id,view.Id,XYZ(x,y,0))
Viewsplaced.append(view.ToDSType(False))
OUT = viewsplaced
Make Sheets
sheets = IN[0]
views = IN[1]
x = IN[2]
y = IN[3]
OUT = viewsplaced
The error implies that you aren’t capitalizing your booleans (True, False), but your code doesn’t show that, so I’m not entirely sure of what’s going on.
You use ā€œNumberā€ in the for, but [number] in the code. Verify all your capitalization for variables.
I had two other capitalization errors in the python. Thanks so much everyone! works great now!
