Error In Python Script
Hello Everyone,
I am creating python script to apply view template.
Everything working well but at line 78 there is error (I have upload error image for your reference).
Could you please help to solve this error?
Thank you.
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
clr.AddReference("RevitAPI")
app = uiapp.Application
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
element = UnwrapElement(IN[0])
# Define the overall all plan view template name
template_name_11 = 'B-150_OVERALL IBMS PLANS_300'
template_name_12 = 'E-150_OVERALL POWER PLANS_300'
template_name_13 = 'E-250_OVERALL CONTAINMENT & EARTHING PLANS_300'
template_name_14 = 'E-350_OVERALL LIGHTING PLANS_300'
template_name_15 = 'E-450_OVERALL LIGHTNING PROTECTION PLANS_300'
template_name_16 = 'T-150_OVERALL FIRE DETECTION & ALARM PLANS_300'
template_name_17 = 'T-250_OVERALL STRUCTURED CABLING PLANS_300'
template_name_18 = 'T-350_OVERALL MASS NOTIFICATION PLANS_300'
template_name_19 = 'T-450_OVERALL ROOM MANAGEMENT SYSTEM PLANS_300'
# Collect all floor plan views in the document
collector = FilteredElementCollector(doc)
floor_plan_views = collector.OfCategory(BuiltInCategory.OST_Views).OfClass(ViewPlan).ToElements()
# Loop through the floor plan views which contains 'OVERALL' & 'IBMS'
for view in floor_plan_views:
    if 'OVERALL' in view.Name:
     if 'IBMS' in view.Name:
        # Check if the view template exists
        view_templates = FilteredElementCollector(doc).OfClass(View).ToElements()
        template = None
        for vt in view_templates:
            if vt.Name == template_name_11:
                template = vt
                break
        if template:
            # Apply the view template to the current view
            view.ViewTemplateId= template.Id
OUT = view.ViewTemplateId
Add an output to confirm your list of views and templates. I’m guessing you have an item in there somewhere that isn’t what you think it is - likely a view type or incompatible view template.
EDIT: I also can’t run your code as the indenting is off at the ‘IBMS’ check. The code still runs but that whole loop is being skipped. Are you expecting to update multiple views or just one? Because right now you’re only returning the final view.
Here’s a bit of cleaned up code that might get you started:
out = []
    template = None
    if 'OVERALL' in view.Name and 'IBMS' in view.Name:
                template = vt
                break
        if template:
        out.append([view,template,view.ViewTemplateId])
OUT = out
Right now I’m returning the view, the template, and the Id just so you have an idea of which views you’re dealing with.
Hello @Nick_Boyts,
Thank you for your quick response.
I am expecting to apply view template to multiple views.
Currently old view template is applied for those views & now trying to apply new view template.
I am at learning stage and trying to create python code.
Appreciate for your help.
I have updated python code as below but giving error at line 75 (refer attached snip)
import sys
import System
def tolist(obj1):
	else: return [obj1]
out = []
    template = None
                template = vt
                break
        if template:
            view.ViewTemplateId = template.Id
OUT = out
Hi @nilesh.katkarNS59L
try this:
# Try to start the code
try:
    #import the common language runtime (CLR) so we can access .net libraries in the Python environment
     #import System
    import System
    #import the .net List class
    #add the Revit API to the CLR
    clr.AddReference('RevitAPI')
    #importing the autodesk namepace to the python environment
    #importing all of the Revit DB namespace as DB, to the python environment so we can be sure we catch what we need in development
    #import the Revit services namespace to the Python environment
    #import the document manager class to the Python environment
    #import the transaction manager class to the Python environment
    #the current document
    # Create Filter to get FloorPlan Views with conditions
    filterV= System.Predicate[System.Object](lambda x : x.ViewType == DB.ViewType.FloorPlan\
                                                    and not x.IsTemplate\
                                                    and "OVERALL" in x.Name and 'IBMS' in x.Name)
    # Create Filter to get FloorPlan View Template with conditions
    filterT= System.Predicate[System.Object](lambda x : x.ViewType == DB.ViewType.FloorPlan\
                                                    and x.IsTemplate\
                                                    and x.Name == template_name_11)
    # Collect all FloorPlan views in the document from filterV
    filtered_Views = List[DB.Element](FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Views).OfClass(ViewPlan).ToElements()).FindAll(filterV)
    # Collect ViewTemplate in the Document from fiterT
    filtered_Template = List[DB.Element](FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Views).OfClass(ViewPlan).ToElements()).FindAll(filterT)[0]
    # Start transaction
    for v in filtered_Views:
        v.ViewTemplateId= filtered_Template.Id
        out = "Success"
    # End transaction
# Catch errors if occur
except Exception as ex:
    out = repr(ex)
OUT = out
I tested for 2 views…
Hello @Kulkul,
This script working as expected.
Thank you.
