Connect your codeblock with 7 into index in your getatindex node
now you feed in linkinstance it had to be document
are you sure index 7 contain rooms…think i need some of your dataset if i should find a solution
I have sent the plan and dynamo file I have; in the direct message box
Thats what i do in post #7
ok thank you
Are you sure there are rooms in the Existing phase? Can you pull apart the RoomAtPoint node and run the contents in the graph to see what errors you’re running into?
All that being said, it would be way easier to adjust the room calculation point of the terminal families to be accurate. Then you can just get the rooms directly from the terminals.
air terminal set parameter mark by room and number.dyn (29.4 KB)
I have attached the revit files and my dynamo work, can you help me how to fix this? (sorry again for the inconvenience to the forum)
You need to use the appropriate lacing so that each terminal is checked against every room. You’ll then have to match those list levels with the filter to get the terminals to be grouped by associated room. Again, all of this depends on if the terminals are actually inside the room boundaries. It would be way easier to just modify the Room Calculation Point in the terminal families and get the room directly from the terminal. That’s the whole reason for having the Room Calculation Point in the first place.
