Continuing the discussion from Revit duct equipment:
air terminal set parameter mark by room and number.dyn (19.4 KB)
These are the last works I have, I wanted to bring it up again, maybe we can find a solution
i am faceing a similar issue
Can you check first if room calculation point is on… you can also based on your linked roomes, creating MEP Spaces…
by the way check also your list.Levels
KR
Andreas
I solved the problem, I understand what you mean, the room numbers are not posed correctly in any way. I also need to create spaces as you said. I guess I have to deal with that now. Do you have any opinion on this subject?
opinion regarding what ? MEP-Spaces and Rooms?
most important thing is that you client is fully aware to have a design-freeze. Where you can work on!
On a constantly changing project is difficult to make any kind of calculation…
KR
Andreas
I don t understand what you want to say
you mean the topic MEP-Spaces and Rooms ?
yes i want to create mep spaces from linked rooms, and i don’t do these for a client, i do it purely for learning
sorry, i am a little bit traumatizet… i am fully in project work… and People with a lot of money behave like a diva ![]()
OK… Information mapping can be intressing for you.
KR
Andreas
be aware you need same numbers… a correlation between element.count and parameter to fill!
i recomment you to create a new topic, for getting more answers.
KR
Andreas
do you have linked elements ? i think you have to say your link room bounding
thanks to god, that you are not in a real project… ![]()
