Revit categories 2018 vs 2019
Hi all,
I’m writing a script for my office with data-shapes in which I access certain categories (wall, floors, roofs, etc…).
The script is designed for users with no Dynamo knowlege at all, thats why I use data-shapes.
I’ve written the script in Dynamo 2 with Revit 2018 and everything runs fine.
Now my office needs the same script running with Revit 2019, where the pre-selected categories suddenly return different categories as if the node saves an index rather than a category. (See images for reference)
Did anyone else encounter this behaviour?
I could just save a copy for 2019, but since some projects stay in older Revit versions I would rather not have to manage multiple versions of the same script, because it is constantly evolving.
Any suggestions are very welcome!
Greets,
Yskert
Hey,
One solution would be to use a “Category By Name” and then type the desired categories in a string node or code block with quotation marks.
Johannes
Hi Johannes,
such an obvious solution.:sweat_smile:
Thanks a lot!
Haha you are welcome, sometimes the most obvious things are the hardest when working hard at something. =)
Please mark as a solution for future readers!
Already done!
It´s a little off topic, but do you know by chance what to feed into the input of clockworks ViewSheetset.Views node?
It say “var…”.
I’m a little stuck trying to get the view/sheetsets…
EDIT:
Got it, It was in the archilab package…
