Revit API access to Structural Connection parameters
Looks like they are stored in Autodesk.Revit.DB.ExtensibleStorage, and they can be accessed like shown in this sample from the SDK called GenericStructuralConnection:
    /// <summary>
    /// Match properties for detailed structural connections.
    /// </summary>
    /// <param name="activeDoc">The active document.</param>
    /// <param name="message">Set message on failure.</param>
    /// <returns>Returns the status of the operation.</returns>
    public static Result MatchPropertiesDetailedStructuralConnection(UIDocument activeDoc, ref string message)
        Result ret = Result.Succeeded;
        // Prompt to select a structural connection
        StructuralConnectionHandler srcConn = StructuralConnectionSelectionUtils.SelectConnection(activeDoc);
        StructuralConnectionHandler destConn = StructuralConnectionSelectionUtils.SelectConnection(activeDoc);
        if (srcConn != null && destConn != null)
            using (Transaction tran = new Transaction(activeDoc.Document, "Match properties"))
                tran.Start();
                // Do the properties match.
                Schema masterSchema = GetSchema(activeDoc.Document, srcConn);
                Entity masterEnt = srcConn.GetEntity(masterSchema);
                // You could also access and modify the connection parameters.
                IList<Field> fields = masterSchema.ListFields();
                foreach (Field field in fields)
                    if (field.ValueType == typeof(string))
                        IList<string> parameters = masterEnt.Get<IList<string>>(field);
                        foreach (string str in parameters)
                            // Do something.
                destConn.SetEntity(masterEnt);
                TransactionStatus ts = tran.Commit();
                if (ts != TransactionStatus.Committed)
                    message = "Failed to commit the current transaction !";
                    ret = Result.Failed;
        else
            message = "There must be two connections selected !";
        return ret;
You need this as well:
    /// <summary>
    /// Get the Extensible storage schema
    /// </summary>
    private static Schema GetSchema(Document doc, StructuralConnectionHandler connection)
        Schema schema = null;
        Guid guid = GetConnectionHandlerTypeGuid(connection, doc);
        if (guid != null && guid != Guid.Empty)
            schema = Schema.ListSchemas().Where(x => x.GUID == guid).FirstOrDefault();
        return schema;
    /// <summary>
    /// Get the unique identifier of the structural steel connection type
    /// </summary>
    /// <param name="conn">structural connection</param>
    /// <param name="doc">current document</param>
    /// <returns>returns the unique identifier of the input connection type</returns>
    private static Guid GetConnectionHandlerTypeGuid(StructuralConnectionHandler conn, Document doc)
        if (conn == null || doc == null)
            return Guid.Empty;
        ElementId typeId = conn.GetTypeId();
        if (typeId == ElementId.InvalidElementId)
            return Guid.Empty;
        StructuralConnectionHandlerType connType = (StructuralConnectionHandlerType)doc.GetElement(typeId);
        if (connType == null || connType.ConnectionGuid == null)
            return Guid.Empty;
        return connType.ConnectionGuid;
