Revit Adaptive Components Sample File
It looks like the Adaptive component Family might have been removed from the dataset for the Revit Adaptive Components Sample File. Does anyone know what that Family was or have a copy of it? It was removed from the sample files in 2025, 2026, & 2027 as far as I can tell. It was for sure there in May or June, guessing recent point releases overwrote the Sample File.
Not something I have, but if you clue me into where you got it I may be able to track it down for you.
I don’t know what the family was named because when you run the dynamo script, the Family Type selector node defaults to the next item available in the list alphabetically because it cannot find the original family.
Where are you getting the sample file though?
Dynamo. It is listed on the samples inside Dynamo. It has been there for a few releases.
Ok. Likely something that can be found without too much effort then. I’ll flag with the team but likely won’t have an answer until next week.
Do you need something earlier than that?
@Dan_Rosenberg the missing family is found in C:\Program Files\Autodesk\Revit 2027\AddIns\DynamoForRevit\Samples\Data\AdpativePanel.rfa. Once you load it into the Snowdon Towers you should be able to select it in the dropdown. There is documentation on this required action in the first note found in the “Info” group, but the specific path isn’t given.
