Hi folks,
I’ve discovered that the BIM Interoperability Tools add-in causing Dynamo to stop working. I discovered this via a process of elimination after a clean reinstall. I’ve since uninstalled it… although it is a very useful add-in so… annoying.
Now even after uninstalling Dynamo still won’t work…
Anyone had this problem and know a solution?
Thanks.
Can you post your Dynamo log and Revit journal from the session with the error and Althea same from a session without?
Hi thanks for the reply. Where on the C drive are those stored?
Craig
Shit shift + up arrow in Dynamo to bring up the console. There should be a line in there which tells you where they are stored.
You can read about finding Revit Journal files here: Location of Revit journal files
@jacob.small
Is there a link to where i can learn to read journal files?
There are a few AU sessions, but unfortunately nothing really robust and dedicated to the topic. It’s a bit of a ‘learn by doing’ topic even with someone directly educating you. They are a language in and of themself.
A link to an AU session or two will do for now. Thnx in advance
