Good day to All, I’m new to dynamo and very interested to know if it is possible to use dynamo and have my retaining wall protrude 1000mm into & along topography and add a strip foundation simultaneously?
Likely yes.
Of course, diapgragm walls, bored pile walls, sheet pile walls and soldier pile walls. Do you mean protrude 1000mm above the topography or dip 1000mm into the topography. Nevertheless its possible. The only problem: revit does not have those families OOTB, so you need to create these families on your own.
Hi Leonard thank you for your reply.
dip into the topography better describes what I would like it to do. I’m only starting the dynamo free course now, No clue whatsoever. but I will get there. thank you for your pointers.
Even automatically creating the whole excavation shoring is possible:
Look here.
thank you this is insightful !
next up study scripting for dummies.
