Morning,
I hace written a routine with nodes “select model elements” and “select faces”. When i try to use that routine in other file, those nodes doesn´t let to get information. I have tried to close and open the file , delete a create the nodes, conect and disconect,…Somebody knows which is the way to restart that nodes?
Thanks so much!
Are you running in automatic mode?
No, i am working in manual.
Is an action in progress in revit?
I get this sometimes when I run a script while I was tagging items.
Are you able to share the graph so we can try it out?
