Thanks @Aaron_Tang, I sent you a small graph and a portion of the Excel file that is giving me troubles. Please let me know if you make any discoveries!
I found an issue here. Reading small numeric values, result in string output witch scientific notation:
The ImportExcel node reads the values correctly:
The string values can’t be used in other nodes since they are not recognized as numbers.
filed as DYN-5297 - FYI @Aaron_Tang
@Anton_Huizinga @Michael_Kirschner2 Should be fixed by DYN-5297 Import Excel Small Numbers by filipeotero · Pull Request #13680 · DynamoDS/Dynamo · GitHub which will be part of 2.18.0 release.
