Data.ExportExcel Node Error
I am having an issue with the Data.ExportExcel node, it is throwing in error regardless of the input settings. It looks like an issue between Dynamo and Excel. there are no console issues and the error description is too vague to understand the problem. This is the second time it happens. Is this a known issue and is there anything I could do to solve it?
Many thanks for your help.
Is your file path correct? It doesn’t look valid.
I am not able to recreate the same error on my side. Do you have write access to the file location as well as Excel on your machine?
Hi Nick, thabk you for your reply. Yes it is. I also tried without specifying a file path which tends to create the excel file in script directory. I tried with and without a .xlsx file extension. No change.
