Hello everyone, I am an architect, and I am starting to use Dynamo. I work in a company where we create a model in Revit with many families within the same project. When we group all the project areas together, the file size reaches 900 MB, and it becomes unworkable. I have managed to drastically reduce the file size by reducing the level of detail and removing unnecessary curves. However, there are 600 families, and each project area uses different families.
I want to generate a script in Dynamo 2022 that allows me to:
1- Select the folder where all the families with reduced file size are stored (the families with reduced file size maintain the same name as the original families).
2- Once the folder is selected, I need to reload only the families that exist in the currently opened model.
I would greatly appreciate your help with this issue. I prefer to use standard nodes if possible.
Best regards.
@macrot.mq ,
that can be a starting point (document.LoadFamily → ClockWork)
here the code from Clockwork, is not so difficult to make costumnode!
clr.AddReference('RevitAPI')
fampaths = IN[0]
famnames = IN[1]
elementlist = []
booleans = []
for fampath in fampaths:
try:
doc.LoadFamily(fampath)
booleans.append(True)
except: booleans.append(False)
collector = FilteredElementCollector(doc)
collector.OfClass(Family)
for item in collector.ToElements():
if item.Name in famnames:
typelist = list()
for famtypeid in item.GetFamilySymbolIds():
typelist.append(doc.GetElement(famtypeid).ToDSType(True))
elementlist.append(typelist)
OUT = (elementlist,booleans)
KR
Andreas
Can you show what you have?
If you can’t post cause you seem to be new here
Consider using Wetransfer as a workaround
Be smart
