Replace items in lists
Hello there! My question seems simple but for now I haven’t found a solution. I jus need to replace some exact items in list of lists with some other items. How do I do that? List.Replace seems has no use here
your input list has strings
search for has numbers
use this to convert
Ooops, right, that was my inadvertence :grinning:
And one more thing: String.Replace from standart revit packadge didn’t work correctly here for some reason. The same String.Replace node from Orchid packadge worked perfect, pretty weird :thinking:
And also if you have 2 figure numbers like 11, 23 and so on you should use String.Replace Multiple from Clockwork for it allows to replace longer search terms first.
