Replace By Condition (with Any List Structure)
Hi @Dimitar_Venkov
How abt this sublist, do you have any solution?
Design Script in its current form is just not capable of handling these types of list structures. The only option is to know the rank of the input in advance and manually apply replication strategy to match that rank:
If you can’t guarantee the rank of your input, your only other option is to normalize the rank, loosing the original list structure.
I tried my hand at using recursive functions in python and got something to work. Let me know if it helps or if there are any problems.
def recOklist(listx,output):
  temp = []
  for i in listx:
    if hasattr(i,"__iter__"):
      recOklist(i,temp)
      if i == "":
        temp.append("Ok")
        temp.append(i)
  output.append(temp)
outList = []
recOklist(IN[0],outList)
OUT = outList
recOk1
Made another version just to allow more utility with choosing the test and the replace:
def recOklist(listx,output,test,replace):
  temp = []
  for i in listx:
      recOklist(i,temp,test,replace)
      if i == test:
        temp.append(replace)
        temp.append(i)
  output.append(temp)
outList = []
recOklist(IN[0],outList,IN[1],IN[2])
OUT = outList
Only works with single item for inputs 1 and 2, for now at least.
@Dimitar_Venkov @kennyb6
Thanks both, It’s quite much with me, i’m trying to comprehend :slight_smile:
And here is another possible way that would handle any list structure:
