Renumber views in Revit - can't find the springs.element node
I came across this thread and this article . That uses a Springs.Element node.
But when trying to “plagiarize” the code I can’t even find that node. On the picture it looks like it is one of the custom nodes.
Is there a different way to accomplish the same, or a way to find the nodes required? Or would someone be able to post the dyn file?
Hi @enkus,
Looks like it has been renamed.
Thanks. I realized I have to install the “spring nodes” package and I found the “SelectElementsInOrder” node. Will try to re-create. I’m sure I will come back with another noob question :slight_smile:
I’m in need to find more of the nodes. the article also refers to a “clockwork” package. I only could find one for dynamo 2.0. I found about half the nodes. what I’m still missing is:
  • Get built In Parameter
  • Set Built in Parameter
  • Passthrough
  • Springs.Number.ToString (I found a node called Number.toString, but that has 2 inputs, and not one)
Seems like I’m too stupid to copy someone else’s work :slight_smile:
Viewnumbers.dyn (22.2 KB)
Time for me to look at this again.
I came across this method and try to re-create it. It seems some packages are outdated and have new node names. I installed the clockwork, rhythm and packages (there seem to be two spring packages).
The above example uses node that is called “Springs.SelectElements(ordered)” and I found one that seems similar. But I have a hard time finding one that mirrors the “Set Builtin Parameter”.
Could someone tell me what package may contain a node like the ones need?
sorry, I’m a noob and just copying someone else’s homework isn’t as easy as it sounds :slight_smile:
Viewnumbers.dyn (21.0 KB)
I believe set built-in parameter is from archilab
Thanks, I think Archi-lab is correct. but I have a problem that I was able to use archilab, but dynamo removed it from the add-ons. i also noticed the archi-lag dll is called “2021”, so I’m not sure if it is outdated.
Before dynamo decided to remove arhilab, I was actually able to select views, and it some how renamed them a bit on its won. which I didn’t expect.
when i opened my file i also go he outdated python error.
It looks like I’m on the right path, but I’m struggling with the packages. Like i have the “Lunchbox” installed, but it doesn’t show up (it is in the packages folder)
Edit: and I’m using the Dynamo editor right out of Revit 2022. I know there is a core editor or something. I’m not sure what the difference is or if one is better.
so i think i got Archilab installed after I found this thread.
Apparently the file name doesn’t really declare what Revit version it is for, at least not in a way that makes sense to me.
But whatever the new version is, it doesn’t seem to have the nodes the old one had.
Is there a package that works for this for Revit 2022?
I didn’t realize dynamo is so finicky about new versions and it looks like for every new Revit version one has to hope all the packages also update without losing old nodes.
