Renaming Civil 3D Corridor Assemblies
What is the correct way to rename Civil 3D Corridor Assemblies? I tried it this way and it looks like the Name property in a list of Assemblies is Read-Only. Perhaps there is a node or command to rename these? I’ve tried the ObjectExtensions.SetParameterValueByName node, however there is no Parameter for Assembly Name. Any help is appreciated! Thanks
The CivilObject.SetName node should do the trick.
Also, the Assembly.Name property should be writable. Are you using the correct obj class?
This one worked for me:
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
assembly = IN[0]
with adoc.LockDocument():
    with adoc.Database as db:
            # Place your code below
            assemblyid= assembly.InternalObjectId
            asseblyobj = t.GetObject(assemblyid, OpenMode.ForWrite)
            asseblyobj.Name = "Test"
            # Commit before end transaction
            t.Commit()
            pass
OUT = 0
But, the solution @zachri.jensen suggested is more convenient.
That did the trick, thank you.
