Hi, do you know about any easy solution how to rename existing property set definitions? I need to add same prefix to all of them. Do you have any tip? Thank you.
I’m not able to test this but it could be worth a try. Maybe try the ObjectExtenstions.SetParameterValueByName node in the toolkit? The ObjectExtensions.GetParameters node could help to see if “Name” is parameter of property sets definitions or if it even works as an object.
Thank you Omar, ObjectExtensions.GetParameters doesn’t work.
I’m not aware of a way to rename a PSD but you can create new ones with the toolkit.
Hi, was someone successful with this task?
Today it would help me again with projects when requirements change.
Hello, is there any update? Tried this using Python but it does not work.
