CivilObject.SetName not working
Hi all,
I have a list with structures, and a list with the corresponding names. I use the node CivilObject.SetName to set these names to the structures. However, the node doesn’t do anything.
I tried using list levels, therefore, the @L2 is selected, but not using the levels also doesn’t work.
Does anybody know why it doesn’t do anything?
Have you checked if the names are changed in Civil 3D, or are you only going off the node output preview?
Thanks for your reply. I was indeed only going off the node output. Turns out it changed the name correctly. Thanks for pointing out!
