Rename in-place components
Hello.
I’m trying to rename several in-place components, I created importing an IFC file in Revit…something like 400 elements…
I noticed that in-place component don’t have any parameter value set for parameters “Family Name” and “Type Name” (string), but only parameter “Family” and “Type”.
Using “Element.SetParameterByName” and “Element.SetName” (Clockworks) I didn’t manage to solve this task.
The only way is to manually rename the in-place component from the project browser…is it possible to automate this using Dynamo?
Thanks.
Work it out.
Element.SetName in this case needs to be applied to family and/or type, not to element.
hi @m.ravelli
i can not find FamilyInstance.Type :neutral_face:
Im using dynamo 2.0.3 and revit 2018.3
family%20type
I’m using Dynamo 1.3.4 and Revit 2019.
It should be a standard node.
Try explore the browser: Revit \ Elements \ FamilyInstance.
In Dynamo 2.0.3, it says "Use Element.ElementType " :slightly_smiling_face:
1%20-%201
