It does not work to "set name element"
It does not work to set name element. I have upload the revit file. (Before open it, please rename the rvt file to rte. Because I cann’t upload the rte file) Thanks!
rename testing.rvt (836 KB)
Revit 2019
testing rename=.dyn (13.5 KB)
Hi @sdzbrian,
You can’t rename instances. Instead rename the floor types with the Element.ElementType node.
testing renameV1.dyn (15.0 KB)
You can’t set the name of System Family. Are you trying to set the name of Floor Types?
Edit: Follow @Alban_de_Chasteigner graph to set the floor type names.
Thank you so much!!!
Thanks a lot !!!
