Hello everyone.
I’ve managed to create a script with a pyhton node inspired in some Clockwork Package code to pickup all the Type Names of a certain category and rename all of them adding a prefix. It works pretty well, the only problem is that I can’t find a way to exclude the types that already have the prefix in order to not have elements with a Type Name with infinite repeated prefixes every time I run the script.
Attached is the script image and this is the code inside the Python Node:
import sys
clr.AddReference('RevitAPI')
items = UnwrapElement(IN[0])
names = IN[1]
def SetElementName(item, name):
if item.GetType().ToString() == "Autodesk.Revit.DB.FamilyParameter":
try:
doc.FamilyManager.RenameParameter(item, name)
return True
except: return False
try:
item.Name = name
return True
if isinstance(IN[0], list):
if isinstance(names, list): OUT = [SetElementName(x, y) for x, y in zip(items, names)]
else: OUT = [SetElementName(x, names) for x in items]
if isinstance(names, list): OUT = SetElementName(items, names[0])
else: OUT = SetElementName(items, names)
Just use String.StartsWith. If the element begins with the prefix use the current name, otherwise add the prefix.
@Nick_Boyts could you please help me with the Python function?:
if not item.GetType().ToString().StartsWith(IN[2]):
try:
return True
try:
item.Name = name
return True
Not sure what I’m doing wrong because it is still adding more and more prefixes
You’re not getting the name of the parameter. You’re comparing the type again.
Thank you @Nick_Boyts but it is now returning only false values
if not item.Name.StartsWith(IN[2]):
try:
return True
try:
if not item.Name.StartsWith(IN[2]) == name:
item.Name = name
return True
I know this is not a Python learning forum but if you have any clue that could help I’ll be thankful
Output all of your values before checking them. That way we can compare and be sure that the values your code is using are actually what you’re expecting.
This is how I finally solved it:
import sys
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
elems = tolist(UnwrapElement(IN[0]))
outList = []
for e in elems:
id = e.GetTypeId()
elemess = doc.GetElement(id)
nombre = elemess.get_Parameter(BuiltInParameter.ALL_MODEL_TYPE_NAME).AsString()
if not nombre.StartsWith(IN[1]):
elemess.Name = IN[1] + nombre
OUT = outList
Thank you @Nick_Boyts for your help.
