I’m using the “Element.SetName” node from clockwork in 2021 to rename families. It works fine in 2020 but it nothing is updating when I use it in 2021. Is there something I’m missing?
A couple things to try:
Check for an update to clockwork package in 2021. It’s possible that if you don’t have the latest version for 2021, it wouldn’t work
Try deleting the SetName node, and then recreating it and plugging it in in 2021. If you are using the same script you made in 2020 in 2021, it’s possible there is a versioning issue. Deleting and replacing the node in 2021 should grab the correct version of the node if that is the issue.
