I followed this tutorial to Elevation Views from Rooms:
I did some minor modifcations such a searching for Rooms with a specific name,
My aim is to rename the Elevation Views according to the Room number and name they are in.
This works for one Room I have located on one Floor Plan:
In the project browser:
It makes all the Elevation Views. However, my script fails to rename the Elevation Views correctly if I place multiple rooms. When I place a Room on a different Level I also get an error.
The Node View.ElevationByCurve seems to create names for the ElevationViews.
My attempt at renaming multiple Elevation viewsfails.
Here I can select the list item to rename a specific ElevationViews by Room, I tried flattening the list. But then it does not rename the ElevationViews anymore.
How can I rename all the ElevationViews with the corresponding Room Name and Room Number?
The Dynamo script:
maak_aanzichten_van_rooms_v2.dyn (100.2 KB)
