We built a local package with around 400 custom nodes.
Now i would like to rename these nodes (text-editor) to the latest naming standards.
Preferably I would not rebuild the nodes, and leave the existing graphs intact
I have tried this in the past and it messed up the layout of my nodes big time.
Layout likely will change as your node names change length. I recommend ‘scaling up’ the graph on open to prevent much of this type of issue using either the bulk graph resizing tool I’ve posted elsewhere, the graph updater built into newer builds of Dynamo, or the “graph resizerer” which is built into Monocle.
Once you scale up slightly you can usually quickly correct any issues which come along the way, or just leave the added white space between nodes.
Thanks for your response @jacob.small, but what i meant is that the layout of the custom nodes itself is messed up. So all (nested) nodes inside are lying on top of each other.
Yeah - same method. That said editing the raw text is possibly messing with the json structure of the .dyf in a way which creates a corrupt layout, which is causing things to reset. Make sure you aren’t changing any GUIDs, other than perhaps the one for the full definition.
I think I’ve found a working method.
NB! Always make backups and do the following only at your own risk.
Open the custom node in a text editor.
Change the “Name” of the node.
Change the “Category” of the node if necessary.
Save and close the text editor.
Change the name of the *.dyf file itself.
Start Dynamo.
Open a graph in which an (old) instance of the newly modified node already exists.
Select everything in the opened graph and click “Delete”.
Click “Ctrl” + “z”, delete will be undone, and a new/updated instance of the custom node will be placed.
The yellow “Renamed” label will appear on the affected node.
Right-click on the custom node in question, and select “Edit Custom Node Properties…”.
Click “OK” in the new window that opens.
The name of the node in question is now corrected and the yellow label has disappeared.
If you open the custom node now, the layout should be unchanged.
If you skipped steps 8 and 9, there is a good chance that all nested nodes are on top of each other in the top left corner.
It’s a cumbersome method, but recreating 400+ nodes and then updating all the graphs isn’t ideal either. I will continue testing with this method, but if anyone has a simpler method, I would like to hear about it.
You may also have better results (and less steps) using a newer Dynamo build for the edits. 2022 is like 8 or 10 versions behind at this point if I recall correctly.
import json
def read_dyf_file(file_path):
with open(file_path, 'r') as file:
dyf_data = json.load(file)
return dyf_data
dir = r'C:\Users\chuongho\AppData\Roaming\Dynamo\Dynamo Core\2.17\definitions'
# read all dyf files
import os
dyf_files = [os.path.join(dir, f) for f in os.listdir(dir) if f.endswith('.dyf')]
print("Totle number of dyf files: ", len(dyf_files))
# read dyf data
dyf_data = [read_dyf_file(f) for f in dyf_files]
Build Dataframe export Excel :
# create data to save excel
import pandas as pd
## save to excel with columns: Name,Category, Description
df = pd.DataFrame(columns=['Name', 'Category', 'Description'])
for dyf in dyf_data:
uuid = dyf['Uuid']
name = dyf['Name']
new_name = dyf['Name']
category = dyf['Category']
description = dyf['Description']
df = pd.concat([df, pd.DataFrame([[uuid,name,new_name, category, description]], columns=['Uuid','Name','NewName', 'Category', 'Description'])])
df = pd.DataFrame(df)
# reorder columns : uuid, name,new_name, category, description
df = df[['Uuid','Name','NewName', 'Category', 'Description']]
df
Export Excel
# save to excel
df.to_excel('rename-name.xlsx', index=False)
Rename with your rule in excel
Load new rule excel (400Node ++) and replace Name.Category
# load excel to rename name
import pandas as pd
df = pd.read_excel('rename-name.xlsx')
df
Rename mapping with uuid and save
import json
import os
import pandas as pd
return dyf_data
# Directory containing dyf files
# Read all dyf files
print("Total number of dyf files: ", len(dyf_files))
# Read dyf data
# Load Excel file
excel_file_name = 'rename-name.xlsx'
df = pd.read_excel(excel_file_name)
# Create a mapping of uuid to new names
uuid_mapping = dict(zip(df['Uuid'], df['NewName']))
# Update 'Uuid' field inside each dyf file
uuid = dyf.get('Uuid', '')
new_name = uuid_mapping.get(uuid, '')
name = dyf['Name']
print(name)
if new_name:
print(f"Update uuid for {dyf['Name']} to {new_name}")
dyf['Name'] = new_name
print(f"Uuid not found for {dyf['Name']}")
#Optionally, you can save the modified dyf_data back to the original .dyf file
#with open(os.path.join(dir, f"{new_name}.dyf"), 'w') as file:
#json.dump(dyf, file, indent=4)
# Print or further process the updated dyf_data
print(dyf_data)
Warning : I don’t have time to recheck, you need recheck code by your self and don’t test with real folder contains dyf package.
