Dynamo 2.0 Unable to change name custom node
Revit 2019
Dynamo revit 2.0.0.4654
Dynamo revit 2.0.0.4655
i am unable to change custom node name
if i change the name it will return back into its original name
does someone have the same problem?
i already placed it un github
First I have heard of this.
Can you provide a link to the GitHub page for others to reference?
Thanks.
This is not specific to 2.0, it‘s been like that forever. There are two ways to rename a custom node:
  1. rename the dyf file and change the node name in its source code (using a text editor).
  2. simply open the custom node in dynamo and use the Save As command. Note that this approach will save the node with a new guid.
Thanks Andreas.
I already used the method to create a new one and copy and paste from old to new.
but using text editor is much better.
