Floor from Walls.dyn (14.4 KB)
Usually adding some picture help, I didn’t know if I got your case correctly but if the case is 4 Walls intersecting each other like the one in the photo, and you want to draw floors in between them . Use this script , Just select the 4 walls and the type of the floor needed and it will draw the case.
You can find the node from this package
