the problem is i don’t know what parameters exist in the families…i have a complete list of possible parameters.
So i need to read the parameters of the family then check with the list do a boolean check before i feed it into the deleteparameter node.
Sorry for being late, but I am building a new hardwood terrace these days at my house… so there is not that much time for playing around with Dynamo
@Arno_De_Lange, do you by any chance have a default family type in your document? If not then this will give errors. It is a kind of strange that Revit can handle to make families that don’t have a default family. But using the methods in csharp cant handle that. In those cases, you need to establish a default family. Instead of building this feature into each node have I created a generic node for this.
thank you for responding…there are more things in live then Dynamo and Revit…hopefully you can enjoy your terrace soon and work on it with a cold beer.
i am not sure what you mean with a default family type…what is a default family…you mean a family just out of the basic directory…i do have a family that is adjusted added parameters and object styles…so that gives problems…?
Finally, I finished the terrace… you are right, there is a life outside forum
Try to see below… this family has no default type. The field with type names is grayed out. This is a most common way families look like if you have your types stored in txt files.
Sorry for not being aware of the original question, but @MJB-online made me aware of this while he suggested me to make a node for getting the FamilyDocument parameters. He was completely right, that one is missing
New version of the Orchid package is available --> 130.2.07 and 200.2.07
