Remove script created line work after completion
Hi All and thank you for your time.
I have a dynamo script which creates views from the point of the sun at different hours of the day.
The script works great. However, in the process the script creates line work which is visible in the model with no way of selecting it or hiding it.
Is there a post script function i need to run or someway of turning off the geometry that dynamo has created in the Revit model.
Thanks,
Daniel
You mean these blue lines?
You’ll have to find node thats creating the lines in your script. Then right click on it and uncheck ‘preview’
This will turn off the preview in Dynamo and Revit.
Those lines in revit disappear anyway once you shut your file down. They don’t print as well so if you want you can ignore them.
Ahh! Fantastic.
Thank you.
