Remove Revit Line Pattern Prefix
Hi All,
I am new to this forum, and I appreciate your guidance in fixing a Dynamo script that was created to remove the prefix of Revit line patterns.
However, it is not working. I have attached the image of the script I tried to create for this.
As a new user, I am unable to attach rvt or dyn files here.
Revit version using : 2019.2.6
Dynamo version using: 2.0.4.12685
try this
Cordially
christian.stan
Thank you. Unfortunately it didn’t work. The result is the same.
Best
Kamal
Curious,
you are fine in manual mode, and had applied it once.
cordially
christian.stan
The script worked in Revit 2020 but not in Revit 2019. I am marking your reply as the solution for versions above 2019. I will revert if I find a solution for the 2019 version
Thanks much.
Best
Kamal
@christian.stan
After updating the Clockwork package (Element.SetName) and DynamoIronPython, it worked in Revit 2019 as well.
Package_Updated
