hi guys , I want to delete all line styles which was imported from AutoCad files into our revit file , I try to find some nods that pave the way for me to run the script of deleting line pattern in revit.
is there any recommendation ? although there is one way in the forum , i didn’t understand how it was work !!!
i don’t have any things in here but there are lots of line pattern in additional setting > line pattern !!!
ThanK you for your kindness BUT i don’t see Element.Delete NOD , is there anyway that i can find it or take it !
I believe the Element.Delete node is from the archilab package.
yes should i install this package on Dynamo ?
Are the ones you’re trying to delete called IMPORT … ?
I just put the word IMPORT in as an example.
Also, if each linetype has a different name and there are not similarities why use dynamo. Use Revit to delete!
yes you right but i think that there is anyway to delete all of the line patterns with any names they have , there are too many pattern which loaded into our project
You don’t want to delete every, single line pattern surely?!
If you do… just plug the line patterns into the delete node
I strongly suggest you don’t do this.
Pyrevit is also a great option for this.
Thank you all for your comments on this post!! While the Script itself is a nice time saver, working through the reasoning and why some of the earlier examples didn’t work was the real winner for me, super helpful. I feel like a Kindergartener who just traced his first letters! this one is going on the fridge for a while! LOL
