I am looking for a way to remove an existing DEM file from a grid surface and add an updated file, I only see ImportFromDEM method to create a new grid surface with a DEM file. can someone help me with this, I am using the Civil 3D 2023 version, python or code block are my preferred approaches.
Thanks for the reply.
This is really important for me. Can you please give me an idea of how this can be done either with code block or python? I tried with the below code, but it’s not working. Please help me.
Load the Python Standard and DesignScript Libraries
import sys
Add Assemblies for AutoCAD and Civil3D
clr.AddReference(‘AcMgd’)
clr.AddReference(‘AcCoreMgd’)
clr.AddReference(‘AcDbMgd’)
clr.AddReference(‘AecBaseMgd’)
clr.AddReference(‘AecPropDataMgd’)
clr.AddReference(‘AeccDbMgd’)
Import references from AutoCAD
Import references from Civil3D
The inputs to this node will be stored as a list in the IN variables.
dataEnteringNode = IN
aeccSurf = IN[0]
FilaPath = IN[1]
editor = adoc.Editor
civilDoc = CivilDocument.GetCivilDocument(adoc.Database)
aeccSurf = surf.InternalDBObject
Remove the current DEM file
aeccSurf.DEMFilesDefinition.RemoveAll()
Add the new DEM file
crs = civilDoc.Settings.DrawingSettings.UnitZoneSettings.CoordinateSystemCode
aeccSurf.DEMFilesDefinition.ADDDEMFile(filePath, crs, False, 0)
Save changes to the surface object
aeccSurf.DowngradeOpen()
aeccSurf.UpgradeOpen()
with aeccSurf.Database.TransactionManager.StartTransaction() as trans:
trans.Commit()
Assign your output to the OUT variable.
OUT = 0
aeccSurf.DEMFilesDefinition.RemoveAt( i )
