As you can see in the script, what I am looking for is to create a surface where the first input allows me to assign a name for the new surface and after this add in surface editing “paste a surface that I select from my list”
There is no script to review?
Can you attached dyn file
import sys
try:
clr.AddReference(‘AeccDbMgd’)
clr.AddReference(‘AeccPressurePipesMgd’)
clr.AddReference(‘AeccRoadwayMgd’)
def create_surface(surface_name):
with CivilApplication.StartDocument() as doc:
with doc.LockDocument():
civilDoc = CivilDocument.GetCivilDocument(doc.Database)
with doc.Editor.StartUserInteraction(civilDoc):
surf_table = civilDoc.Fsurfaces
new_surface = surf_table.Add(surface_name)
doc.Editor.WriteMessage("Surface created: {}".format(surface_name))
return new_surface
def paste_surface(surface_to_paste, new_surface_name):
result_surface = None
editor = doc.Editor
with doc.TransactionManager.StartTransaction() as transaction:
try:
surface_editor = civilDoc.Editor
surface_editor.Command("._EDIT")
surface_editor.Command("._PASTE")
surface_editor.Command("._END")
result_surface = civilDoc.GetSurfaceFromEditor()
if result_surface:
result_surface.Name = new_surface_name
doc.Editor.WriteMessage("Surface {} pasted and named successfully.".format(new_surface_name))
doc.Editor.WriteMessage("Error while pasting and naming surface.")
except Exception as e:
editor.WriteMessage("Error while pasting and naming surface: {}".format(str(e)))
transaction.Commit()
return result_surface
if __name__ == "__main__":
surface_to_paste = IN[0] # Superficie a pegar desde el nodo
new_surface_name = IN[1] # Nombre de la nueva superficie desde el nodo
# Crear la superficie base y pegar la nueva superficie sobre ella
result_surface = create_surface(new_surface_name)
if result_surface:
result_surface = paste_surface(surface_to_paste, new_surface_name)
# Devolver la superficie resultante
OUT = result_surface
OUT = str(e) # Enviar el mensaje de error al nodo para visualización
If you wrote this code , Use this method
TinSurface.PasteSurface Method
